question for those running the speedway alternator bracket
I have the speedway setup for an F-body alternator on my Fairmont, ive noticed after racing at the track the last time that the belt jumped on the tensioner (see pic below) - last night I was messing around on the highway on the way home from a local cruise night and raced from a 45mph-ish roll, got home and found the same thing - belt had jumped. friend of mine has also had this happen with their bracket (he has a truck alternator setup)
has anyone come across this? if so what did you do to fix it?
Is the pulley on straight? Is it on tight? Something is pulling it to the front.
Edit: Look to see if you cam get a wider pulley to put on there? Or maybe one with a higher side rib just to see if that works.
I use that bracket, and I've spit a belt a couple times. It's usually when the motors sees rev-limiter. I just carry a spare belt and a wrench with me in case.
As a note, other people have troubles with stock set ups, and there are upgraded tensioner set ups available people have luck with.
Love the car by the way!
Come to think of it, I had to move up to a solid tensioner after adding a S&P low-mount A/C (which runs on the main sheave). The belt wouldn't jump grooves, but would jump up and down to the point of coming off when the air was switched on. The factory spring just wasn't strong enough to hold the longer belt. Also remove the belt and check all your pulleys for axial play, that can be a factor too...
no play in anything, tensioner is new. im thinking of putting an idler under the alternator - that section of belt is pretty long so im wondering of there is deflection there causing the tensioner to move excessively. ill post up what I use and how it works
I use the same set up with the exception of a manual belt tensioner. I never ran it with a spring loaded tensioner but I did notice the belt does jump around quite a bit when you get off the throttle. I cranked down the tensioner to limit it's movement.
