ls4 Dod delete, should I change oil pump?
Old 05-26-2014, 02:34 PM
supercharged024's Avatar
Default ls4 Dod delete, should I change oil pump?
So should I change the oil pump? I've heard I should. Which one should I use?
Old 05-26-2014, 06:15 PM
chuckrv6's Avatar
Yed i did ,i used ls1-4.8 or 5.3 oil pump. Install the ls4 spring into any of these, will be close to 80 psi start up pressure. Hot pressure 60-65 psi. I did this on both of my 5.3 gen 4 swaps. Chuck ls4 malibu & ls4 turbo s10
Quick Reply: ls4 Dod delete, should I change oil pump?
