T-56 reverse lockout ?
Old 05-26-2014, 05:53 PM
59belair's Avatar
Default T-56 reverse lockout ?
donor engine and trans are from 02 Camaro (LS1 - T56) . Will the ECM handle the load of the reverse lockout solenoid, or does it require a solenoid to operate it? from what I see, it's wired directly to the ecm, but that seems like a lot of pull for a straight connection.
tanks,
59
Old 05-26-2014, 09:53 PM
Red89GTA's Avatar
why not delete it?
Mine's disconnected (electrically), just push through it to get to reverse.
Old 05-26-2014, 10:36 PM
59belair's Avatar
Originally Posted by Red89GTA
why not delete it?
Why not make it work the way it's suppose to?
Old 05-27-2014, 06:19 AM
1slo5ohh's Avatar
Because that takes work lol. I'm curious too because I'll be using a t56 with my swap.
Old 05-27-2014, 06:55 AM
darksider's Avatar
I just hooked up my switch to the ECM, works like a dream. Very easy, switched 12 volt to one wire, hooked up the other wire to the ECM.
2004 LS1 out of a GTO.
Old 05-27-2014, 07:23 AM
1slo5ohh's Avatar
sounds easy enough. thanks
Old 05-27-2014, 08:00 AM
1964SS's Avatar
tanks,
59
I wired mine straight to ECM. Factory did it this way without issues. Why change it. Mines worked fine for 2 years now.
Old 05-27-2014, 09:20 AM
rickyzZ28's Avatar
I have mine hooked up to a switched 12 volt source with the computer grounding the other wire. On another car I am doing for a friend that does not have a computer we are just going to wire the switched 12 volt source into the brake lights so it will only activate with the brake being pressed. It is a LT1 T56 but is in a 67 Camaro with a 396.
Old 05-27-2014, 11:19 AM
bczee's Avatar
I just used a line lock switch on my stick. 12+ and ground the other. I have a Viper T56, so the vss is not connected due to the different signal output. I use a GPS speedo.
Old 05-27-2014, 11:39 AM
59belair's Avatar
OK cool. thanks. it appeared to go straight to the ECM on my (poor) schematic, but I figured I'd better check before creating expensive smoke.
cheers,
59
Old 05-29-2014, 10:07 PM
Red89GTA's Avatar
accidentally eliminated it from the harness, works just fine
Old 05-30-2014, 07:27 AM
the1theycallthe1's Avatar
Here's what i did.....
https://ls1tech.com/forums/manual-tr...me-people.html
Quick Reply: T-56 reverse lockout ?
