lsx into 66 gto fuel fitting question
Old 05-28-2014, 07:29 AM
taylor8907's Avatar
Question lsx into 66 gto fuel fitting question
Hey guys,
Still working on my swap and am close to being ready to fire the motor and just need to set up the fuel system. I have a Wix 33737 filter regulator like the corvette style and i have the fittings for the side where the fuel comes from the pump and the return back to the tank but cannot figure out what fitting fits into the large output to the fuel rail. What did you guys use. The output is not threaded and looks barbed like something pushes into and clips.
Thanks!
Old 05-28-2014, 07:36 AM
ls1nova71's Avatar
The line that goes into it looks like the fittings on the other side of the filter, smooth with a flare about half an inch up. Dorman makes repair lines with that style of end. Also I know I've seen fittings that fit it, but not sure who makes them. Someone will come up with a source I'm sure.
Old 05-28-2014, 08:20 AM
oldgoat69's Avatar
I am fairly certain that Russell or Earls (and most likely others) offer the fitting you need. Dorman offers the repair part to make up the OE style plastic lines if you are going that way. If you search these vendors you will find the options.
Old 05-28-2014, 12:44 PM
1989GTA's Avatar
The part I used was a Russell 640940.
Old 05-28-2014, 12:56 PM
Nasty N8's Avatar
We keep all those fittings in stock and can help setup the fuel system properly.
Old 05-28-2014, 01:45 PM
taylor8907's Avatar
thanks! ill see if that takes care of it.
Quick Reply: lsx into 66 gto fuel fitting question
