98 vette fuel return question
Old 06-14-2014, 11:57 PM
Meangreen1's Avatar
Arrow 98 vette fuel return question
I have a 98 vette 5.7 and as you know has the regulator in the fuel. I bought a FPR/filter and need to know what's the best way to make it all up. Cap the one on the rail? Input please
Thanks for your time
Old 06-15-2014, 12:26 AM
ls1nova71's Avatar
I think the best way would be to not use a $50 filter/regulator since you don't have to. just use a regular filter and run the return from the rail back to the tank.
Old 06-15-2014, 12:31 AM
Meangreen1's Avatar
I was thinking that but already bought it I would then need to buy an in line filter. Any specs ppl want to share on that?
Old 06-16-2014, 12:32 PM
Meangreen1's Avatar
Looking for more info on this before making the lines.
Old 06-16-2014, 12:54 PM
gagliano7's Avatar
I have never done it but I would just plug the return on the rail. I have the returnless setup on my motor and there is just an input for the fuel so that will be your setup if you plug the return.
Old 06-17-2014, 10:46 AM
Meangreen1's Avatar
Would that still work with it plugged?
Old 06-17-2014, 10:55 AM
ls1nova71's Avatar
I don't think I would try it, you would have two pressure regulators if you did that, not to mention you would have to plug it off so 58psi of fuel would never spray onto a hot engine. I would find a returnless rail. Where are you located? I would swap you rails if you're close.
Old 06-17-2014, 11:24 AM
Oscar Will's Avatar
I have run the Corvette filter/regulator bolted to my rear frame rail for better than 10 years with no problem. I like the idea of having just one line of fuel running all the way to the engine. I've changed the filter once in 35,000 miles...no problem. My return line is less than 48" long.
Old 06-17-2014, 11:33 AM
ls1nova71's Avatar
I have 72k on mine and have never changed the filter, they work great. What I was saying is I wouldn't block the return line of a 97-98 corvette fuel rail. 99-up cotvette and 98- up f bodies are already returnless.
Old 06-17-2014, 12:35 PM
bczee's Avatar
Why not just pick up a 99+ fuel rail...you can get them pretty cheap. That way you can keep and use the FPR (GF822). Your feed line can be used as is. Just do away with the return for the rail (or shorten).
Have you considered that you well have to add the quick release fitting and add the barb in the feed and return lines to use thr FPR ?
either way you have some work and parts that are required to add the FPR to you 97/98 system.
BC
Old 06-17-2014, 09:41 PM
Meangreen1's Avatar
Thanks for the feedback guys.
Quick Reply: 98 vette fuel return question
