Another Porsche swap!! 911 996 w/ ls6 v8
#63
That would be cool, we would have to schedule it with the porsche clubs! If their in person reactions are as funny as their online ones!! lol!
On a side note, do any of you running and driving swapped 911 owners have any tips/tricks to re-filling/bleeding the cooling system?
-did you vacuum fill it?
-did you elevate the rear of the car so the coolant would go all the way up to the radiators?
I'm going to try the elevate the rear thing tonight and i'll report back, otherwise the only other thing i can try is the vacuum fill, but i'd rather not spend the money.
#64
#65
Hmmm, cut coils and blown out struts vs some Bilstein Pss9 coilovers!!! And i thought it handled swesome before! lol
Coils cranked all the way down!! Squattin!!
Here is a before the coilover swap pic, Porsche sat a little too high after the "heavy american boat anchor" was put in! lol
#67
Air Box?
I just browsed your thread and it's cool...
I'm 75% done with my 996/LS1 conversion and used the KEP adapter setup, stealth pump, corvette filter/reg, stock water pump...
I'm struggling with the air box area as there is such limited room and the turn is so sharp to run a K&N pod off to the side...what is your solution?
Also, what radiator bottle is that?...I'm currently using a thunderchicken (tbird) from the mid 90's..
Bought a vacuum system to burp as I've been having a little struggle whenever I have to add air to the system.
Mark - Mobile, AL
Mark - Mobile, AL
#68
Mark - Mobile, AL
Mark - Mobile, AL
The radiator tank is stock, the aluminum can is just an oil/breather catch can.
Here's a pic, i'll get some better ones and post them up.
#70
Once i get this M***** F******!!!!!!! coolant system bled!!!! I tried to jack the car up and down but its still heating up. I'm going to have to order a vacuum fill system. Time to
Maybe this will hold you over on the vids.......a little catalytic converter to open air action!! lol
#73
Yup, i unhook the top hose and pour the coolant down one side till its full then pour it down the otherside till its full. I think there is too many ups and downs on the way to the radiators and back to simply pour in the coolant. I just ordered a vacuum fill kit, hopefully that does the trick!
#74
I was running a 185 stat & kept having issues with getting too hot 210 +
So I finally got sick of Fing with it & drilled a couple small holes in that stat & it has never had a issue since. It runs 200 all day long with the ac on & sitting in traffic.
#75
after another go at it today and some more researching online i might have the hoses routed incorrectly! I'm going to check this out in the morning, if this is the problem i'll be happy but also mad!!
today i got the car warmed up and it was tipping 210 on the gauge so i cut it off. Go to the front of the car and the radiators are cool to the touch. There is no flow to the radiators, i'm sure of it.
Its not the t-stat bc i gutted that thing out long ago! lol. Wont be a problem in the Houston summer 100+ heat, i'll replace with a proper tstat later on.
Its got to be my hoses routed wrong...ie: tstat housing probably going to the top of the radiators and the outlet at the top of the waterpump is probably going to the bottom of the radiators.
#76
reinstall tstat, drill 2 1/8" holes in the thermostat. make sure none of your hoses are kinked, then pressure fill the system with a cheap pump up sprayer for your lawn. simple, easy peasy. yes I have done it. 5th Porsche lsx swap completed, 2 more to go.
#77
thats the plan....already bought a vacuum fill off fleabay though, so when that comes in i'll fill'er up! I'll go back over my hose routing and make sure theres no kinks......man this is the hardest part of the swap soo far!!! lol
#78
you can get them from home depot for 23.00 its a hand pump pressure sprayer for your lawn or weeds or bug spray whatever you want to use it on. fill your coolant system the regular way, then when full make a rubber stopper or equivalent that fits tightly in the neck of your radiator or fill neck, put a hole in the middle that this pumps wand can barely push thru, fill the sprayer with antifreeze and start pumping it up. it will help if you have a bleed port or a overflow bottle that it can bleed into.
#79
Here's my new setup:
red circle- Open vent, only used to bleed system, valve stays closed under normal operation.
blue circle- radiator overflow from tops of both radiators, i also t'd my steam ports into this.
yellow circle-expansion tank outlet goes to the heater outlets of the waterpump which have been t'd together.
If the vacuum fill fails i'll try to reverse fill the system through the radiator overflow tube with the pressurized system (weed sprayer) i got from home depot.
Here is a pic of my vacuum fill setup:
