If you make your own mounts how do you mount the motor?
How do you know where to mount your motor? Do you just sit it as low and as far back as it will go?
The problem with doing your own mounts that I can see is that a drive shaft that is made for your car with an LS motor in it may be the wrong length.
Thoughts on this?
Also, I've heard that to swap a motor into a 240sx I'll need a GTO oil pan. Is it just the pan itself? Or does the pick up need to be from a GTO as well? Would it be possible to just fabricate my own oil pan? I'm pretty handy with a welder
Thoughts on this?
You will need the GTO oil pan, pickup, windage tray etc or you could buy a prefabbed setup or make your own. There are companies like Canton which have a nice setup for the swap.
If your pinion is easily adjustable and you can fabricate your own oil pan,headers and transmission crossmember, then you can put it wherever you like. If none of those things are possible then you need to choose the location and inclination angle wisely or you can end up with an oil pan and headers that hang too low and driveline vibrations and shortened U-joint life.
The canton pan is a nice piece, but it will hang very low if you have your engine low slung in the chassis.
Thoughts on this?
Thoughts on this?
Andrew
Mounts are not the place to cut corners...
258 bucks sounds like bargain!
Andrew
Possible to fabricate your own pan? Short answer, yes. But it depends on your skill and confidence. Can you make a leak proof tank on the first pass? It's harder than you think and most people can't.
Practical to fabricate your own pan? In my opinion, no. I CAN build nearly anything I need, however there are companies who know much more than I about important topics like oil control, etc. than I ever care to. I'm frugal and like to make or reuse things all the time but I can save the money to buy a pan faster than I could design, test and build one. Simply making an accurate pan rail with all 12 bolt holes properly aligned is beyond most home fabricators. Then you have to design it around the chassis, make the sides, weld it up, make sure it's oil tight and not warp it in the process... no thanks. I'll find a pan that is close and move the chassis if I have to.
S-Chassis and LS swap = not cheap no matter how frugal you attempt to get.
http://www.summitracing.com/search?S...yword=12654HKR
Andrew
Andrew
Aside from Summit having the mount/crossmember kit listed for $258, the painted versions of the Hooker longs tubes is listed for $658...that comes to a total of $916.
Height wise yes, but I'm not sure about their fitment in terms of diameter. There are plenty of aftermarket replacement poly mounts for the C5/C6 however do work, which is why we designed the engine brackets to work with them.
