corvette alternator to fbody plug
Old 07-28-2014, 03:04 PM
LSjim's Avatar
Default corvette alternator to fbody plug
hey i had repinned the alternator plug so that the one wire is now in the "f" terminal but now that i did that it is barely seeing 12 volts. Before when it was wired in the "l" terminal i was seeing 18 volts. i am using a fbody ecu and all the info i could find was carbed setups please any info would help
Old 07-28-2014, 03:36 PM
1981TA's Avatar
put it back in the original pin, and put a 470 ohm resistor in-line.
Old 07-28-2014, 04:18 PM
LSjim's Avatar
and that is it ??
Old 07-28-2014, 04:36 PM
33willys's Avatar
Default Alternator rewire
I tried to put a DR44 on an '03 5.3 and wire it to the computer but it would not charge, just fail to the 13.8 volts. Once I installed the correct alternator and changed the plug back to stock it started charging again. Guess it's something to do with the alternator internal wiring.
Old 07-28-2014, 05:21 PM
LSjim's Avatar
yea its very annoying lol i have to run the corvette alternator due to the new lsx transplant procharger kit
Old 07-31-2014, 03:18 PM
LSjim's Avatar
so i put a 470 ohm resistor in line on the original pin location still charging at 18.8volts does any one have a pin out to run both wires
Old 07-31-2014, 07:55 PM
1981TA's Avatar
Does your connection look like this?
Old 07-31-2014, 09:08 PM
VIPERSLYR's Avatar
I have the corvette alt on my 99 f-body this is the alt I used off of a 2000 corvette it's a ac delco part # 334-1280 you don't have to re pin anything just plug it in and it works perfectly fine just like a stock f body alt. You can also get a different regular put in the alt that will eliminate the exciter wire and will self regulate its self
Old 07-31-2014, 09:16 PM
VIPERSLYR's Avatar
I forgot to mention if your using a 98 f body PCM what I stated above won't work as it's different than 99+
Old 08-02-2014, 08:07 PM
LSjim's Avatar
Is there a difference between a c6 alternator and a c5?
Old 08-02-2014, 08:13 PM
VIPERSLYR's Avatar
I don't believe so no, I over thought it and done tons of research and I believe it's over thought it's a plug and play deal
Old 08-03-2014, 08:30 AM
1981TA's Avatar
For what it's wrth, mine is a C6 alternator. Was yours purchased used? Have you had it tested? Most auto stores will do it for free. If you don't mind cutting the wire, you could try jumpering it directly to the battery, with the 470. Resistor in-line. If you still get 18.8 volts, I would think either the resistor is shorted, or your regulator is bad.
Old 08-06-2014, 04:39 PM
LSjim's Avatar
Thanks guys when I get home I will pull the alt and bring it to get tested it is a new refurbished but we all know how faulty they can be lol and yea when I had it stock plug with no resistor 18.8v and with resistor 18.8v and when I changed the to the "f" terminal it wasn't charging at all
Old 08-06-2014, 05:32 PM
69 Ghost's Avatar
You need to check the year the alternator came from and look at the Corvette wiring setup. If it is not using 'f' terminal then you will probably need to wire it like a Vette and program the PCM for the terminal type or at least figure out the differences based on the wiring. I went to a 04 GTO OS with a Camaro wiring and it would not charge until the setting was changed and the PCM was reprogrammed to a 'f' type charging. Same problem no charging until the change. No wiring was changed.
Old 08-13-2014, 02:12 PM
LSjim's Avatar
so i would need to access that in hp tunners? and did you also do a 470 ohm resisitor?
I tested the alt and it passed all of them i am lost!!!!
Old 08-13-2014, 05:01 PM
LSjim's Avatar
any one?????
Old 08-13-2014, 09:22 PM
1981TA's Avatar
Do you have pics of your setup?
Also, you may wish to check this reference for the correct pinout connection from your alternator to your ECU. If you are using a GM ECU, then the 470 ohm resistor will not be needed. If you are connecting the brown wire directly to "keyed positive" (or the battery, for testing), then you will need the resistor.
Old 08-14-2014, 10:06 AM
LSjim's Avatar
yea it is the correct pin out i am running a psi wiring harness and i am running a 2002 camaro ecu
Quick Reply: corvette alternator to fbody plug
