smallest starter
Old 07-29-2014, 08:46 PM
Gregamuffin's Avatar
Default smallest starter
what's the absolutely smallest ls1 starter? dropped an ls1 in chevette and im really cramped for space. anyone have some actual measurements for the smallest mini starter?
Old 07-29-2014, 09:01 PM
stereojnky's Avatar
I know the t56 Gto uses a small starter. The regular ls1 starter won't fit the bellhousing.
Old 07-29-2014, 09:38 PM
V8Rumble's Avatar
Cool
You, sir, are my hero! (Or, quite possibly maniacally insane, there seems to be a non-trivial amount of overlap there...)
Yeah, that kinda goes without saying...
I'm going to be watching this thread because several days ago I read where someone mentioned a mini-starter that can be clocked to ANY position, rather than just one of several pre-drilled hole positions, & with any luck that'll be mentioned again... AND for pics of this vehicular madness that you speak of...
Old 07-29-2014, 09:47 PM
it's super close to running but, this starter nonsense is a pain
Attached Thumbnails smallest starter-img_3334.jpg   smallest starter-img_1590.jpg   smallest starter-img_2380.jpg   smallest starter-img_2672.jpg   smallest starter-img_2671.jpg
Old 07-29-2014, 09:58 PM
V8Rumble's Avatar
Wow, that's insane... I'm guessing there's an interesting build thread behind those pictures! I started to think "Huh, there's more room under the hood than I would've expected..." - but then I saw that the radiator isn't in yet. Yeah, that's gonna be interesting... Cool project!!
Old 07-29-2014, 10:00 PM
radiator is going to have to go in front of the front support. there's a surprising amount of room to work on the engine itself! any idea where you saw info on this starter?
Old 07-29-2014, 11:24 PM
V8Rumble's Avatar
One of the threads on here, I'll have to see if I can't find it using a search engine...
Old 07-30-2014, 03:34 PM
MX6.0's Avatar
You're may be thinking of my header build thread.
Almost all of the info about the PowerMaster 9509 starter is located on page 2.
https://ls1tech.com/forums/conversio...l#post17220275
No problems with the starter to date.
Old 07-30-2014, 04:17 PM
how long is it as a unit? are there any starters where the solenoid is mounted remotely for an LS1?
Old 07-30-2014, 04:23 PM
MX6.0's Avatar
The exact measurements are in the link.
I'm not aware of one that has a remote solenoid.
Old 07-30-2014, 06:27 PM
thank you, and it lets you clock it 360 degrees?
Old 07-30-2014, 06:33 PM
Nissan LS240's Avatar
I've got a msd mini starter at home I'll take some height and width measurements, let me know if need different measurements
Old 07-30-2014, 06:37 PM
in fact you can have it if you pay for shipping, the headers on my 240 hug the engine quite a bit and everything bolted up but the header laid on the starter, drove it awhile like that until one day I tried to start the car while it was running and broke the clip that holds the plunger in place, starter motor still works but not sure what needs to be replaced other than the clip, I replaced the starter with the LS1 fbody starter and its quite a bit longer than the msd one but its positioned in a way that clears my headers
Old 07-30-2014, 07:42 PM
V8Rumble's Avatar
Cool
YEP!! It was your thread (post #27 in fact), thank you!! I think I'm going to spring for one of those starters for my own project - if memory serves, the starter that I have offers two positions with the pre-drilled holes, one runs it into the headers, & the other one knocks it right into the crank(?) sensor... Being able to clock the starter in between those two positions will solve one of the problems I have to deal with!!
Old 07-30-2014, 08:35 PM
yes please take those measurements, i just don't know what else i can do if i don't find something smaller. i'll have to shave down my motor mounts which will be a huge bitch now that the engine is in the car and i can't really get a grinder in there. i appreciate all the help so far. any other options what so ever?
Old 07-30-2014, 11:59 PM
1981TA's Avatar
Holy mother of cats, what did that poor little car ever do to you?
I bet your car is going to be an absolute beast when done. You should drag race the LSx Prius.
for more clearance in front, maybe you can source an accessory drive setup from a LS4 car (GP GPX, Monte Carlo SS, LaCrosse Super).
Old 07-31-2014, 10:51 AM
MX6.0's Avatar
A Prius is a fat pig compared to a Chevette. No comparison.
Old 07-31-2014, 10:58 AM
DEFYANT's Avatar
I think the 9505 Powermaster or the APS/MSD Starter will be your best bet.
Old 07-31-2014, 05:30 PM
MSD starter is 7 3/8"long motor is 3 1/2"wide 5 1/2"tall with solenoid, mounting plate is 4 1/2"wide 4"tall, and the motor can be clock in three different positions to bring solenoid closer to the block, let me know if you need other measurements
Old 07-31-2014, 07:10 PM
thanks for all your help guys the one i ordered from summit came and i was able to modify my motor mount plates and clock the starter in such a way that i got it all situated! thanks again
Quick Reply: smallest starter
