ls1 swapped into a 95 z28 harness modifications
LS1Tech Sponsor
We can modify your existing harness, or we can build you a 100% brand new harness. Only ours will be 100% PLUG AND PLAY with your 1995 Fbody. It will also have the factory firewall grommet just like your factory harness!
Modification- $400
New PLUG AND PLAY harness- $750
Either way you go you will not have to wire in ANYTHING. Plug, Play, and turn the key.
Modification- $400
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
