my dipstick does not want to go fully into the block. Need help
Motors a 08 l92 and I am having trouble with the dipstick even going into the tube fully. I had a 98 to 02 ls1 pan on before and now have the autokraft pan and it is the same results. The tube was bent a good bit to fit around my headers so I ended up getting a new truck dipstick and tube but ended up with the same results with barely any bending to tube.
I'm at a loss I can not get my dip stick fully into the motor. I have roughly 3 to 4 inches of the dipstick sticking out. Need some help I am pulling out my hair and using every curse word there is in my nice and quiet neighborhood. ...
I wonder if the area where the stick goes into bottoms out with the longer truck dipstick. It suggests the f body but I don't know the length difference of both to verify if it is bottoming out or not.
We did cut the dipstick and tube down on the stock ones and it still didn't go all the way in. Thing is if I did bottom out in the pan, it would have had oil on the stick. Mine didn't really have anything on it.....
i have mine bent im using the H3 pan and stock truck dipstick. It took a few times getting mine in there I had to turn it around not sure if that helped at all but everytime i remove it its a fight have to keep taking out and turning then it slides in. My is 5.3 in a 79 camaro with headers flipped
Is there a twist in the oil dipstick? I know when I modded my pan, I went to a wrecker and grabbed 5 dipsticks of different lengths, I put in 5 quarts of oil, and used my original dipstick and it showed I had to much oil in it, any ways I found a dipstick that was the right length, but had a twist at the bottom of it, put it in a vise between some wood and took the twist out and it works great.
No twist on the dipstick. Straight and flat. My question is, where the dipstick goes into the psn....is there anything that could be blocking it from going in from inside the pan? If I push in on the stick, it starts to make bends in the dipstick.
I am using a Corvette tube and dipstick in my L92. When you insert the dipstick into the tube, there will be a point where you will have a little resistance. Grab the dipstick close to the tube so it doesn't kink, give it a little twist and it will slide right in...
Andrew
Andrew
Andrew
Andrew
Not sure about the tray. My buddy modded the stock one to fit the ls1 pan but I'm sure he installed it correct. As for the sound, it doesn't make anything other than just feeling snagged pn something.
I've tried everything under the sun and it seems like nothing will help. I will say this, I took the old dipstick into and was messing around with it sliding the dipstick in an out.it wouldn't fully go through so I looked at the bottom and it appears where the o-ring is on the outside there's a lip on the inside of the tube, I wonder if I can smooth that out because I believe that's what Catching my dipstick. Thoughts?
Does your dip stick have a plastic tip or is it all metal?
Andrew
I like the low profile of the dipstick. The f body one is recommended for my pan . But I've heard of guys using different sticks and them not getting the correct "full" reading on th stick. Line it has the correct amount of oil as recommended but the stick reads too much or vice versa
