Vats help?
Old 09-01-2014, 08:56 PM
key4's Avatar
Default Vats help?
99 ls1/ 4l60e in a fairmont. My harness is a psi and I have a 411 PCM. On hptuners vats is set on pwm. Car will start for about 2 seconds and die. Not sure what pwm means but do I need to set it to none?
Old 09-01-2014, 08:58 PM
casey38boost's Avatar
Set it to None, and write calibration. Should fire up. If not you might have to "relink vats" under one of the drop down menus.
Quick Reply: Vats help?
