Stiff/poor brake feel on LS1 mustang... Hydroboost problem?
Hey guys,
So after blowing 2 4.6l cobra motors I finally had enough sense to fit an Ls1 into my SN95 cobra.
I got a great deal from a friend on a forged HCI 347 that is now in the car and running thanks to a PSI stand alone harness and a built T56. One of my few small problems is my braking system. I've got a hydroboost setup on the car being fed by the factory GM ls1 power steering pump. My brakes feel super stuff and the car stops very poorly. I purchased the borgeson GM pump shim kit to reduce the pressure for the mustang rack..
What could It be?
Pressure too high?
Bad pump?
Bad hydroboost?
What could It be?
Pressure too high?
Bad pump?
Bad hydroboost?
any tricks to getting the air out easier?
Borgeson said in their instructions that the mustang rack be approx. 1000psi. but after some searching another forum it said the PSI rating is about 750.
could that help?
The lower the pressure the longer it takes to pump up the accumulator in the hydroboost, but you also need the correct amount of volume of fluid. I would also make sure the air is out of the system. Proper bleeding procedure will take about 30 minute to an hour depending on how foamy the fluid is. Most likely if the system worked before the swap, it is in the pump pressure or the pump itself. F250s are switching to a larger orifice for correct pedal feel. You might try search that also.
bleeding procedure:
http://www.agrperformance.com/AGR-In...structions.pdf
bleeding procedure:
bleeding procedure:
bleeding procedure:
Yea the system worked before the swap. Just this is slowing me down at the moment
