SN-95 LSX swap build thread
#42
I guess I don't understand what is going on in the pic above. Are you only mini tubbing the front half of the rear wheel well in order to keep the OEM rear shock mount? I've never seen that done but I guess it would work OK.
Also what 64post mentioned above about cutting holes in the floorpan and dropping the cage through to the ground in order to weld the halo works quite well. I have done that many times and have gotten the tubing very flush to the roof while still having plenty of clearance for a TIG torch.
#43
As far as cutting holes in the floor for the cage. On the SN-95 it is easy to cut the roof off because all of the welds are hidden under panels when you put the car back together. It turned out great the cage is right against the head liner.
#44
I had hoped to start assembling the motor today, but the ring pack we got is not right. So we worked on the getting hte hood fitted and fenders lined up.
Racecraft Dzus Rail
Both Dzus Rails Installed
A little more adjustment needed, but pretty close.
Racecraft Dzus Rail
#46
We haven't been able to do a lot of work this week, but we have a most of the body work done and will be painting it soon. Sent rings back to total seal with a piston so we get right ones back. Waiting on Pro-systems carb and Crane to make the cam.
Modified wheel well finished
Door jam area ready for paint
Driver's side ready to paint
4150 Stinger Plate Kit
#47
Fixed rusty trunk hinge today wow does seam sealer suck!!! Also got sheet metal for the trunk floor.
New Hinge ready to be sealed
Trunk after spare tire well was removed
Soon to be new trunk floor
#50
I have no idea what it will weigh. We have a lot of stuff to put back in it still. For now we just are doing the fronts, and that is only so the 29.5x10.50's will fit wit a 7.25" backspacing on the rims. Later on we may do tubs and coil overs in the rear.
