Front and Rear oxygen sensors the same?
Old 09-24-2014, 09:01 AM
bluezq8's Avatar
Default Front and Rear oxygen sensors the same?
I am building a harness right now and I would like to use the rear O2 sensor wiring for the front O2 sensors because I am running long tubes. My reasoning for this is so that I can avoid lengthening the front O2 wires.
My question is, Can I run "rear" O2 sensors as "front" O2 sensors? I know they serve different purposes, but, do they read differently?
Old 09-24-2014, 10:09 AM
ramairetransam's Avatar
yes but you have to switch some pins on the pcm . do a search on here , its doable .
Old 09-24-2014, 10:18 AM
bluezq8's Avatar
I knew I would have to switch the pins, much easier than cutting/splicing.
My question was more towards the functionality of the oxygen sensors. I read the thread about switching the pins on a F-Body, but they use the same connector between front/rear. My harness is a truck harness and the connectors are different.
Old 09-24-2014, 10:41 AM
bczee's Avatar
Yes. I have done it before. Just switch the pins as stated.
Old 09-24-2014, 10:46 AM
bluezq8's Avatar
Cool, thanks guys!
Quick Reply: Front and Rear oxygen sensors the same?
