Power steering ?
Power steering ?
I have an ls-1 in my 51 Chevy five window pickup. The power steering pump is brand new. The issue is it is whining every time i turn the wheel, I called myself getting the air out by turning it lock to lock. Is there any cure or reason for this?
Didn't know there was such a thing. The pump is a regular gm pump that went with the (Tahoe motor) , and the rack is from a ford. I did not know that there were different pressure for each pumps and or racks??
Also check where you are returning fluid to the pump. Mine was very loud and eventually boiled over because I returned the fluid to the upper return, but as soon as I changed it to the lower return everything was great. I think the upper return was for vehicles that had hydraboost.
Ford racks are very popular, and I believe pressure lowering kits for LS-style pumps are common. Barring any other issues like kinked or constricted lines, I'd do a little research around PS pump pressure kits, and run with one that is appropriate for your rack. I don't think they are that expensive.
The pump is paired with the rack that came with the vehicle it came out of. In your case, it would be the Tahoe. The high pressure side of the pump for a newer PS system can be in the neighborhood of 1600 to 1800 PSI. Some older systems can take it (like the steering box on my car - which is made for between 700 to 900 PSI) the steering just gets real light and twitchy. Others can't and eventually start leaking. So people buy pressure lowering kits or special low pressure pumps.
you need to reduce the pressure...
GM pump puts out about 1300 psi, ford rack is looking for 900-1000 ish
Borgeson makes a kit with some shims and a special tool to use in the process..
http://www.jegs.com/i/Borgeson/153/899001/10002/-1
