LS2/E40 serial bus ?? (can bus)
I have a LS2 from a 06 GTO with the E40 computer. I am looking at the Speed Hut gauge package and would like to use the Can Bus set-up.
Is the Pin 1 and 2 on the C1 labeled Serial Bus the same as the Can Bus ? If so have you guys connected to the tan wire?
Did it operate the oil, water and volt meter?? Was the fuel gauge input from the stock wiring harness (68 Camaro)
Thanks
BobH
Thanks
BobH
