GTO LS2 2 yoke/companion flange
I'm doing my first LS (which is also my first RWD) build into my RX7. On my 2006 GTO T56 I have a flange with a rubber coupling on it, can I remove the whole set up and put in a different standard slip yoke? Does this factory flange assembly just slide out? I'm learning about V8's as I go and there's no manuals for the GTO. Thanks for any help.
Andrew
Bob and Matthew,
How did you deal with the stud that protrudes once you unbolt the GTO yoke? If you just install a regular slip yoke it will be stuck too far out...
Andrew
Andrew
Time to do some searching via part number.
Andrew
*edit* I was looking at various pictures and that tails housing looks like a 4th gen f-body...<shrug>
