Another Friggin 5.3 turbo chevelle
Old 06-27-2016, 10:41 AM
  #161
FOUROHSICKS's Avatar
Soon....
Old 06-27-2016, 11:37 PM
  #162
BLKMGK's Avatar
Can it do antilag? Say a switch used for nitrous and just retard timing? Late burn will spool it even harder and then release it with the brake/line lock...
Old 06-28-2016, 02:10 AM
  #163
8 Second Truck Club
Blown06's Avatar
Originally Posted by FOUROHSICKS
Go ahead and pull a datalog on the Holley EFI while you are on the t-brake with the 2 step. Report back with data on how much rpm swing you are getting please. I'm curious.
Old 07-01-2016, 10:21 PM
  #164
Thumbs up
I need to look in to that. Makes total sense man thanks
Old 07-01-2016, 10:45 PM
  #165
I need to setup the datalog feature once I do that I'll log it. I have it set at 3475 to 3450 so it's supposed to be bouncing between those two rpm's but, a log should show what's actually going on. It does have a tip in stumble and I blame the knockoff 80lbs injectors. I will get the Holley injectors as soon as I get some money for car parts. Maybe I get the 160lbs injectors and do e85. Gonna be another $1000 plus with bigger pump and junk... Fack it
Old 09-02-2016, 07:29 PM
  #166
C clip eliminators with 33 spline axles from strange
10point cage
Spherical bushings
Factory 12bolt
120's
QA1 single adjustable coilovers
Strange spool 4:10's
It worked thanks denmah
Soon
Done almost
Quick Reply: Another Friggin 5.3 turbo chevelle
