01 LS1 harness modification. off road rig questions.
I am building a off road rig, and I am powering it with a LS1 out of a 01 f body the harness and ECM i believe are out of a 01 caprice. I don't need any gauges, cooling fan control, or any other non engine management circuits, I just need the engine to run. is this a relitivly easy job, or should i pay the 250 to have it done? I also have the alternator out of the F-body, does the ECM control that too? I cant seem to fnd a pinout and diagram for the bare harness and what i need...
X2 on LT1Swap.com If you have an electrical background and don't mind doing the research its not bad at all. But, 250 is well worth it. And if you are not 100% sure what the components came out of, it gets quite a bit more difficult.
