Gto ls2 in '86 Monte carlo ss
Old 05-10-2015, 10:42 PM
  #61
RowJon13's Avatar
My older brother had a 87 MC SS, sold it though to finish up his 67 El Camino. You have one clean car!
Old 05-10-2015, 11:27 PM
  #62
2ndGenLSX's Avatar
Very nice!
Old 02-29-2016, 12:55 AM
  #63
onebadbowtie86's Avatar
Couple small updates. Put close to 1k miles on last summer with no hiccups. Love the new 4.30 gears over the 3.73's. I can use 6th gear now and its a blast ripping through 1st-4th gear.
I swapped out the stock ls2 intake with a new fast 102, hopefully I see some gains there. Also made a little skid plate for some insurance with the gm muscle car pan. I plan on pulling the motor next winter and swapping on the holley pan. Before spring gets here I would like to get a set of the stainless hooker headers on the car and sell the hedmans I currently have. Also doing the trunnion bushing upgrade on the rockers and throwing in some 7.425" pushrods.
I'm getting some valvetrain noise when hot, mostly just hearing it through the headers. I measured and had .050" pre load, so hoping the longer push rods will help out.
Ready for spring to get here so I can get the car back out!!
Old 02-29-2016, 05:27 AM
  #64
Garrett1982's Avatar
Very clean build. Looks really good.
Old 05-01-2016, 11:57 AM
  #65
Went to the opening day test and tune at the local 1/8 mile. Started out pretty slow since the concrete for the first 100 feet or so was brand new. Its much harder trying to launch the car on the low profile drag radials. My car needs bias ply's if im going to get some 1.6 60' times. I was able to get a couple good runs other then poor 60 foot times in before the car broke. Snapped a drivers side axle shaft.
My best time was only a 7.77, but that was with a 1.9 60' and the car is running over 94 mph, with a best mph so far of 94.43. The ls2 is definitely making more hp then my old carb 383, which had a best of 90 mph in the 1/8 mile. If I can find some better slicks for the car and make it back to the track I think I should be able to get a 7.30-7.40 out of it fairly easy.
http://vid245.photobucket.com/albums...psmpwp3fua.mp4
http://vid245.photobucket.com/albums...psjabvn0xc.mp4
Old 05-01-2016, 12:02 PM
  #66
WS6 #3392's Avatar
Very nice build dude! Love the Monte Carlo SS!
Old 05-02-2016, 09:00 PM
  #67
Thank you!
Moser axles are ordered and going in this weekend.
Old 01-14-2017, 09:04 PM
  #68
truckdoug's Avatar
ay just bumpin this up. how'd the axles work out?
Old 01-14-2017, 09:19 PM
  #69
moser axles are working great. Look much beefier then the originals thats for sure. Was a pretty cheap fix/upgrade. Had to pull the rear all apart though because metal shards every where.
The new tires I was running at the track. I really need bias plys but for a tire I run on the street they were starting to hook at the track. If the axle wouldnt have broke I bet I could have easily pulled a 7.50.
Couple vids from track
That was just a test and tune and I was focusing on figuring my car out and not racing the guy next to me or caring about my reaction time.
Old 01-14-2017, 09:23 PM
  #70
Right now I'm ordering a new 3.5" pst aluminum driveshaft with chromoly slip yoke and pinion yoke. going with solid spicer 1350 u joints. Hopefully gets rid of the damn vibrations Im getting up over 70 mph.
Really want to pull the motor and swap oil pans and do ls1 rear brakes to get rid of the drums. Want to at least do the rear brakes so If I snap another axle it doesn't walk out.
Old 01-14-2017, 10:36 PM
  #71
truckdoug's Avatar
yeah gotta get those eliminators in there for sure. i've been in a car that spit an axle and it was a wild ride to say the least!
Old 01-14-2017, 10:43 PM
  #72
I heard that they tend to leak oil, and I'm not sure if they work with the ls1 rear brakes? Otherwise I would do them. I was thinking if it happened again the disc brakes would hold the axle in?
Old 01-14-2017, 10:57 PM
  #73
truckdoug's Avatar
yeah ive had em leak. there's a couple tricks if you go that route.
but yeah a caliper ought to trap the axle enough to get it slowed down
Old 01-14-2017, 10:58 PM
  #74
truckdoug's Avatar
but really you arent gonna shatter a moser like a stocker, they'll twist and deform the splines. probably check them after each season to make sure
Old 01-14-2017, 11:22 PM
  #75
That was kind of my plan. I'd love to have a 12 bolt/60/9" But I have so much in this rear, and dont want to drop another 2 or 3k on something else. My car is a street car that barely gets driven, and goes to the track once a year if I'm lucky. If this was a 7.5" I wouldnt have put the money into it, but Its a grand national 8.5". Should be strong enough for what I'm doing with it. Luckily my axle shaft snapped right on the launch when I dumped the clutch.
Old 01-15-2017, 09:08 PM
  #76
01cherryreds10's Avatar
Super nice build. I used the same headers on my Malibu but I bought them new along with the engine mounts, and trans crossmember from BRP. Ended up not using the trans crossmember because it didnt fit, and the mounts raise the engine up to let the musclecar pan clear better. Wish the holley parts out when doing my swap.
Moser 28 splines in my 8.5 have went 1.5 60' on a drag radial and sticky track no problems. Although some bias ply with a 6 speed will add some more stress.
Old 01-15-2017, 09:57 PM
  #77
Thanks for the reassurance on the moser axles! I feel pretty confident in the 8.5" now with the new trutrac diff and moser axles.
I forgot to update that I sold the hedman/brp headers and installed a set of hooker stainless steel long tubes. MUCH better header. they were expensive but well worth it. I had to do some minor trimming on my clam shell motor mounts and get an ls3 dipstick but other then that they slid right in. The brp headers were awful in my car because of how low the engine sat in the k member, which is good for engine angles.
Old 01-15-2017, 10:24 PM
  #78
Those look super nice. And they won't rust like the ceramic coated brp's
Old 01-15-2017, 10:36 PM
  #79
Thanks, I really like them.
Old 01-15-2017, 11:15 PM
  #80
EastTnZ28's Avatar
Nice car. I love the Montes. You have any idea of the weight. I havent read the whole thread to see if its been mentioned.
Quick Reply: Gto ls2 in '86 Monte carlo ss
