2006 GTO Throttle Assembly Options Please
Just got myself into a 2006 LS2 from a GTO and don't have any throttle "stuff". What are my options for finding the:
Throttle Position Sensor (TP)
Throttle Actuator Control Motor (TAC)
Accelerator Pedal Position Sensor (APP)
And anything else I need to complete the system from foot to throttle body? Does anybody have part numbers of the assemblies I'm looking for by chance?
So the engine has an E40 ECM. With that being said, do I just need the GTO gas pedal assembly (like the one in the pic) and that should complete the system? Of course I still need to have the harness modified and the ECM programmed for my 1968 Chevelle conversion with a T-56.
The E40 does not use a TAC. The ECU controls the throttle body. You can save some money and use an LS3 gold blade throttle body. Some will tell you it won't work, but that is what I am using. I think I also have a wiring pinout chart. You can get all of the pieces to build a harness at www.eficonnection.com , good guys and fair prices.
I used the same E40 for my swap. I was also missing the OBD and gas pedal wiring. I bought the exact wiring harness shown in your pic with the OBD and gas pedal wiring already attached. Works like a charm.
Here's the one I bought. http://www.eficonnection.com/eficonn...spx?ItemId=848
Most of the wiring in this harness isn't used.
