G Body swap Questions
Getting geared up for the swap on the Monte but have a few questions.
1. has anyone tried the corvette oil pans for clearance?
2. what about building mount pedestals (welded in) instead of using the plates?
3. have any of you just routed the factory harness and pcm and used after market gauges instead of re doing the harness?
I'm not thrilled with the thought of a cut up K member, and using the set back plates wont work as I wont have clearance for the down pipes later. No big deal to change drive shaft length and move a cross member forward an inch.
I've been trying to figure out why so many of these swaps always seem so difficult on the older cars and for the life of me can't figure out why.
I'm using EFI live for the pcm side of life to make life much simpler.
Am I missing something here?
There is a 77 trans am on pro-touring that says to have the batwing pan. Similar to g-body.
I did my ls1 t-56 swap back in 2002 before there were many swap options. I did the cut & rebox the crossmember method to use the f-body pan, notched to use the low mount ac. Made my own mount setup. Modded the factory harness & used aftermarket gauges. Some pics in my photobucket link.
Basically with any swap like these, you have several different options for most issues. Many come down to more labor to save money or just buying something.
Thanks for the input guys! I'll be starting a new thread in the next few days on the swap.
I'm a welder for a living so luckily the fab work is so damn easy for me it's not funny. Been looking at the vette pans as I have lots of connections from my C4 LQ4/LS3 hybrid swap.
I'm thinking about just building some perches to be able to just use the new mount style vs the old clamshells.
Motor, harness and ecu (4.8) arrive in the am,most likely either C5 or C6 oil pan and pick up, rad, fans and condenser arrive later this week, exhaust is care of Z06, keeping the 200R4 for now.
I used BRP mounts and a GMPP pan. If you are a welder you could cut the GMPP one down an inch and the pan would be flush with the crossmember. The best part is the GM one is half the cost of any other aftermarket ones
read your build llorracs, very clean finished product!
Swap and running is my first order of business, mods will come later on.
The body work, paint and interior changes will come later on.
Thanks, wish the car was running right....having wiring issues. But what do you mean abiut the pan not being impressive for 400 bux?
By all means it's a lot of money, but it is perfect for no hanging below cradle, cradle clearance and I have read 0 issues with the pan. The holley 400 dollar one has had many mounting issues. So if you were to spend the money, I'd steer clear of the holley pan.
Vette pan and custom mounts are the way I'm going, Its the same cost as an F body pan but no notching required. Also the F body pan as well as the AutoKraft are dangerously close to the centerlink. The Vette and the CTSV pan are both shorter on the front.
I don't like the way the AutoKrafts are built. for 400 I expect a little slope on the front of the pan for helping drain back and better baffling on the sump. As far as the baffles go, It may help on oil control during cornering but does absolutely nothing for nucleation of the oil. The bungs for a TT setup are nice but it definitely has a lot of room for improvement.
It's obvious that every product manufactured on earth is going to have a percentage of non-spec parts get out the door and Holley's tech department has worked proactively to remedy any such situations if the customer takes the time to put a call in for assistance.
The 302-2 pan is installable in applications that no other pan is (without cutting) and provides the GM engineered structural tie-in to the trans bellhousing to maintain the intended NVH characteristics of the LS engine...no steel pan does that. It also features a sloped front profile to enhance oil drain back and has an available bolt-in trap door baffle for those who need it.
You are certainly entitled to your opinion, but I think readers should be aware that there are many of us who have installed Holley pans without a single issue and enjoyed taking advantage of their fitment features/attributes.
Hey llorracs, I'd like to hear more about the "mounting issues" the new Holley pan has as I've used quite a few of them over the last year and a half and never encountered any but a trouble-free installation.
https://ls1tech.com/forums/conversio...-oil-pans.html
As long as you are buying from a reputable company who stands behind their products then these types of things are usually remedied quickly.
Dealing with product design issues brings far more frustration to a project than dealing with a manufacturing issue as you merely have to make a few phone calls to resolve the later.
I went with a autokraft pan after reading some threads on the holley pan mounting service not seating perfectly.
And a buddy of mine has had a leak front the pan and cannot find out where om the pan it's leaking from.
I agree 100% every company/part has a off part here and there. I just went with what I have heard and buddy's experience. My harness for my car is crap even though many have used them including me before and had 9 issues.
