5.3l conversion wiring gauges
Im in the middle of my 5.3l swap into a 99 tahoe.
Im just trying to see what everyone else has done to get the stock gauges to work.
I have the complete donor truck still . the tahoe has the 5.3l and tranny from an '01 silverado. the computer from the 01 is flashed and got a wiring harness from painless.
Do I need to run 2 sensors one for each computer or how does that work
Any extra info or anything needed just let me know
thanks
thanks
Right on ... i have the water sender all figured out ... just to confirm for the oil sender i just need to remove the 5.3l sender and replace it with the 5.7l sender with adapter
Yes. Adapter and old 5.7 oil sender. You can also use an f body temp sender that way you only have one sender in the stock location. They say the temp gauge won't be accurate but I don't notice a big enough difference to even worry about.
