Can you drop oil pan on Fox w/AJE K member?
Anyone ever tried to remove their oil pan with the motor installed? I have a leaking oil pan gasket and need to drop this thing to do it right. Need to drill the rivets and put a new gasket on. Figured id ask before i try it since i need to remove my hotside crossover on my turbo to have it drop. AJE Kmember with Fbody oil pan.
thats what im thinking but figured id see if anyone tried it and what they had to do if it didnt drop. I could probably unbolt the motor mounts, and unbolt my turbo from the frame and lift the entire thing if i need.
What do you mean by " do it right and drill the rivets"? Im asking because im about to pull my recently installed motor to fix a leaking pan gasket (pass. rear) and wondererd if there were some tricks
