First Timer, Doing LS2 T56 1971 Camaro for my son
Any suggestions and help to make this restore as easy as possible is much appreciated, Im new to this forum and have been reading as much as possible to prevent any screw ups, Plan on total frame up tearing out original drive train this weekend and pulling sub frame to weld up all seams and powdercoat.
If you have done this before could you suggest what engine mounts, crossmember and headers worked for you.
Wiriung suggestions ect........
Want to minimize my mistakes
Thank you and this forum rocks for answers
LS1Tech Sponsor
we can help with the wiring!
One thing that you will find about the ls2 is that it is a special harness most of the time. If it came from a 2005 or 2006 GTO then it will have an E40 ECM System.
If it came from a 2005 Corvette it will also have the E40. If it is a 2006 LS2 from a corvette it will use the E38 system.
We can supply a harness and package no matter which system it has.
Judging from the way the harness is routed on the engine pictured it is from a Corvette. However, with just one picture I have to make an educated Guess!
Feel free to post up with what the year and donor vehicle is and Ill help as best I can!
Bill
BP Automotive
Bill
BP Automotive
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
LS1Tech Sponsor
So it will have an E40 system.
The downfall about that is there are just a few companies out there that support a Harness for that ECM. Most try and get you to switch back to drive by cable and use a different PCM. We full support that system.
We can supply you with a fuel system for your swap, a harness, tuning, Sensors if they were missing, and even motor mount plates. Just about anything you need!
what transmission are you looking at using? I do see a Flywheel in the picture, but I didnt want to assume that you were going to run a manual transmission.
Feel free to give us a call 270-805-1777. Ill help with anything I can.
Bill
Bill
__________________
1-888-467-4491
1-888-467-4491
Take a look at our chassis harness. It's the most complete harness you will find. Our manual for it is over 150 pages itself! You and your son will know all the ins and outs of the wiring on that car once you're done.
http://www.painlessperformance.com/webcat/20112
Regarding the engine harness, as Bill @ BP said, we are on of the ones that don't support the E40. Our harness for that, uses the 0411 computer. More tuners prefer the 0411. However what are you planning to do with the engine? If you plan to leave it near stock, we offer a free reflash with our harness (~$200 value). We'll turn off the anti-theft, set the speedo, fans, etc. If you plan to do any performance mods to it, you'll want to source a local tuner.
That harness is still setup for DBW as well.
http://www.painlessperformance.com/webcat/60520
Either way, you can't go wrong with the help from here.
A quick question you might have that most do, is that the chassis and engine harness are separate of each other. They will be connected via just one wire from the ignition source to trigger the engine harness.
front brakes
POR15 on firewall
Por15
Firewall painted with subframe mounted after powdercoating
rideTech front suspension
Ride Tech Front suspension with coilovers
motor and tranny set
motor in now going to figure out what Front pulley system to go with? Billet Specialties or Concept1
Tomorrow going to try and do some more work on Rear Ride Tech 4 Link system. Doing the work by myself takes a bit longer and some busted up knuckles too
looks like you have some good work going on. I been helping a friend with a body off total strip resto on a 80 camaro. A lot has been done but just about have body ready to jamb paint in & out everything. I replaced both sides of floor, inner & outer tailpanels, pass. side rocker & front 1/4 patched. Also redone top & bottom front leaf spring mounting areas. So I know first hand about work you done.
It's been fun project so far, can't wait to get it on the road hoping by Summer
Update on progress 4 link all installed with 12 bolt rearend and wilwood big brakes. getting started on harness configuration and routing. Waiting on new front pulley kit by Concept One and Vintage Air.
