an fuel lines on fox body
I have aftermarket fuel rails that came with the an lines and fittings for them either -6 or-8. When I removed the motor from my fox (4cl) I just cut the hard plastic lines. so my question is: is there a way to connect these two together and if so, how? or would it just be a better decision to just sump the tank and put in an inline pump and just plumb all new everything? Thanks for your opinions guys
There are ways to plumb using plastic lines and there are ways to plumb using any variety of AN lines, but it is hard to mix and match. I like PTFE (teflon) AN lines with steel hard line running the length of the car.
Andrew
Andrew
The best thing to do is to run a new set of lines. Get rid of all the crusty fuel hard-line on the car. There are adapters that easily convert the stock sender (feed and return tubes on top your tank) to AN. I bought a single length of -6 braided hose and necessary fittings. Use a corvette filter near the tank to prevent having to run more hose and minimize material. Then run a single hose all the way up and connect to your rail. Very easy and nothing will be hacked up. Do it right the first time.
I have a brand new intank 340 pump with 6an fittings welded on the feed and return. used a 94-95 bracket as it has a bigger feed line then 79-93. Fits perfect in foxbodies. Also have the Corvette filter with an fittings already installed (bought it as a kit) This was spare stuff for another car. I have everything to build another LSX stang
