"Shrek" the 1974 Ford F100 5.3/turbo Shop Truck
This is our little promotional project we're working on at the shop. Figured you guys might get a kick out of it. We're just gonna slap the shop name on the door and **** off purists at test/tunes and cruise in's.
Specs below:
1974 Ford f100 2wd LWB
Junkyard 5.3, ARP rod bolts, new oil pump and cam bearings. 130k(ish)
Cam Motion .565/.595 230/238 camshaft
LS6 valve springs
TH400 trans
Used TCI Streetfighter 3200
Ebay "GT45" turbo
Ebay bar/plate intercooler
Truck manifolds flipped with v-bands
Used Tial wastegate
Used JGS blow off valve
Knock off bosch 044 inline pump
Deka 60lb'ers
2.5 bar tune with hptuners, stock 411 pcm
Specs below:
LS6 valve springs
TH400 trans
Ebay "GT45" turbo
Used Tial wastegate
Deka 60lb'ers
I completely forgot I even started this thread, haha.
Truck runs great, we pounded on it all summer, between a few issues and breakages atleast. The converter is nowhere near enough for this combination. As soon as the boost hits the engines at 6k, doesnt matter what gear. But even with a stupid loose converter we put down 534whp and went a best of 11.42@115. Truck is a blast on the street! It gets lots of attention.
Nope i fabricated engine mounts that adapt to factory engine mount stands on the frame. And the wiring was relatively easy, we just started with a truck harness, gutted everything we didnt need, and added a small fuse panel and a couple relay bases. Ford ignition switches a strange in the fact that key-on power is cut during cranking so the easiest solution was to wire in a push button start.
