Couple wire questions
Old 03-02-2015, 03:56 PM
recliner15's Avatar
Default Couple wire questions
I am finishing wiring up my S2000 swap and I just have a few quick questions about a couple of wires that im unsure of.
It is a 2002 Honda S2000 with a 2004 Buick Rainier (DBW) LM4 Engine and T56 Transmission
I am using all F body accessories and intake
I am using the wiring harness from the Rainier and a 2003 Trailblazer ECU with Blue/green plugs and modifying it to work for DBC
The wires I am unsure of what to do with are as follows
CPP Rev Light (grey wire)
TCC Brake (purple wire)
VSS Out (green/white wire)
Off/Crank Voltage (pink)
Also as I understand it the pink wires in the engine harness need switched power - wiring up a new fuse box being easiest.
Thanks in advance for your help
Old 03-02-2015, 08:32 PM
SS409's Avatar
Hello recline15, I will see if I can help you here.
can not find CPP Rev Light on Trailblazer ECU, or is that coming from the 2002 Honda? I think it is for clutch pedal position shift light. do you have a shift light in the honda cluster?
The TCC Brake is for lock up torque converter disengagement, so you don't need that with a T56.
The VSS out is your Vehicle Speed Sensor, Grn/Wht goes to cluster speedometer, the Yel/Blk goes to ABS system.
2003 Trailblazer Instrument Cluster.pdf
2003 Trailblazer Engine Perf 5of5.pdf
Here is a F body with T56 wiring for VSS
2002 Camaro SS Instrument Cluster.pdf
2002 Camaro SS 5.7 6 Speed 4of4.pdf
Could not find Off/Crank but found crank volt witch is PPL and needs power during cranking only. Is that comming off the trailblazer ECU?
Let me know if this helps
Thanks
Old 03-03-2015, 07:53 AM
recliner15's Avatar
Attachment 490124
Attachment 490128
Attachment 490129
Attachment 490130
Attachment 490128
Thanks
First off - Thanks!
CPP Rev light is coming from the Trailblazer ECU but remember I am using the Rainier harness that i am basically gutting - as far as removing emissions related stuff and DBW stuff
So TCC Brake I will cut and terminate
Power during cranking only - what the hell lol. Can I give it a +12v and call it a day?
Old 03-03-2015, 09:17 AM
ls1nova71's Avatar
Where is this wire at? Is it coming from a PCM connector? If so what pin number? Hot in crank only sounds like a signal wire for the starter relay, if you are not using one, then you can delete it.
Old 03-03-2015, 09:23 AM
recliner15's Avatar
Attachment 490124
Attachment 490128
Attachment 490129
Attachment 490130
Attachment 490128
Thanks
It is coming from the PCM connector. I will double check later today the Pin #
I am using a separate starter relay on the honda side of things
Old 03-03-2015, 09:36 AM
ls1nova71's Avatar
If you're using the Honda starter relay, then you most likely won't need the other wire. The starter relays are controlled by the PCM so that they can cut the ability to start the car if VATS is activated (wrong key, etc.) so if you're just using it for some kind of neutral safety/clutch switch, odds are it can be eliminated, but without the pin number I cant say for sure.
Old 03-03-2015, 07:17 PM
SS409's Avatar
First off - Thanks!
Are you sure that is a 2003 trailblazer pcm? I dont think that Trailblazer ever came with a manual transmisson.
What is the servo number of the pcm? Where are you getting your pin out data?
Thanks
Old 03-04-2015, 09:38 PM
recliner15's Avatar
So tcc brake is 33 on the blue connector
Going to trace back Cpp rev later but it's a solid grey wire
Also my ecu serv number is 12576106
Old 03-05-2015, 06:45 PM
SS409's Avatar
since you have a T56 the tcc brake wont be used.
The CPP rev is not need to run the engine.
Since the trailblazer never came with manual transmission I dont see that pin being activated in the software tune. Plus I don't see that pin any where on the mitchell schematics for 2003 Trailblazer or 2004 Buick Rainier.
Thanks
Old 03-05-2015, 07:57 PM
recliner15's Avatar
I've been using the guides and info on lt1swap
Old 03-05-2015, 08:01 PM
recliner15's Avatar
Can I give off/crank voltage the same power that the rest of the engine harness gets?
Old 03-05-2015, 08:04 PM
ls1nova71's Avatar
Did you ever find out what pin the wire is on at the PCM plug?
Old 03-05-2015, 08:10 PM
recliner15's Avatar
Blue 75 for voltage pink wire
Blue 35 for Cpp grey wire
Old 03-05-2015, 08:14 PM
ls1nova71's Avatar
Blue 75 is just another ignition wire, it can be hooked to the other pink wires that are hot in run and start.
Old 03-05-2015, 08:19 PM
ls1nova71's Avatar
I would leave the clutch wire out of the PCM, and just wire a switch directly from the clutch pedal to the wire going to the starter, seems easier that way.
Old 03-05-2015, 08:25 PM
recliner15's Avatar
Got it
perfect
Thanks so much!
Quick Reply: Couple wire questions
