G body Cutlass LS1/4l60e conversion
#61
Can you please post some pics of the GN filler neck fitment? I read several times it is different than the Cutlass and can cause interference issues.
#62
Not pretty but it will function just fine. The kit available at gbodyparts.com is the same. I ran an older G body like that for years without an issue.
#67
So I've been super busy but got the car running everything's going pretty smooth just have a few minor things to sort out... Here's a few updated pics I tried uploading video to photobucket, didn't work I'll try YouTube later.
Car sits higher up front now, should I cut the coils or order drop springs?
Painted valve covers gold, tried to give it a little bit of the olds 350 rocket motor from back in the day without making it look to blinged out!
3" universal x-pipe and matching moroso spiral flows will get dumped.
#69
#72
#74
#77
If I could go back I would've spent a little extra on the g-force crossmember the exhaust humps are spread further apart and bigger. I plan on swapping to a th400 next year so maybe then!
#79
