Ls2 into 1997 - ECU Question
Old 03-16-2015, 03:48 PM
BigBadWhitey's Avatar
Default Ls2 into 1997 - ECU Question
Ok so I've read TheMerv's thread on the swap, and a few others.
My question is - If im throwing in an aftermarket ECU with the swap (bigstuff3) to control the fueling and spark (do as much of the work as it can), can I keep the factory lt1 ECU to run the gauges, or am I going to need to swap to the LS ECU regardless?
Quick Reply: Ls2 into 1997 - ECU Question
