AC on Swap Blue/Green PCM
2007-classic silverado engine/trans in a 67 C10 with vintage air
Using 2007 ac compressor
07 truck is class II air conditioning. Still DBW, with e-fans. What is best way to get ac to work through the PCM. It is a 1MB blue/green pcm.
From my understanding I need to use a different OS, but a van isn't DBW. What is the best OS to use? I'm using EfiLive. or is there a way to select "manual ac" like mentioned for the vette and go that route.
I'm planning to dig around efilive tonight. Sorry, If I'm not asking the right questions, but I've searched and read these threads but I've confused myself:
https://ls1tech.com/forums/conversio...cm-turn-c.html
https://ls1tech.com/forums/conversio...ector-ecu.html
https://ls1tech.com/forums/conversio...ps-others.html
Because the OS that the 2003-07 Silverados use (blue/green PCM) has no 12v A/C request wire, it's on the serial data line. So unless you want to use the A/C controls, which is a module it's self, you have no way of turning it on. By changing the request from serial to manual in the tune allows you to get the 12v request., and the 12v request systems (vans, and 99-02 trucks) use the two pressure switches.
more
I'm on board now. My brother made me a new tune file running an 04 Express Van OS. The wiring diagrams are the same with exception to the cooling fans, A/C stuff, and the van has provisions for cable throttle. We have the tune setup for DBW and Efans.
Next question, how smart is the pcm with regards to a/c? Just off the pressures the PCM has no way of controlling cycle times for the compressor so I am going to assume that I connect my compressor clutch feed wire from the vintage air unit to the A/C request pin on the pcm. So cycle time is controlled by the vintage air box and pcm just makes ac adjustments when commanded.
which brings me to another thought. my VA unit has a binary switch mounted to the evap assembly. Im curious if this would function in place of the factory switch located by the accumulator on the van. I have the other pressure switch still on the a/c comp.
