PSI Stand Alone Harnesses & PCMs for Your LS Swap On Sale @ Hinson Motorsports
Do you do PCM programming? I am running a truck harness and 5.3 computer but have a 6.0 with a LS6 cam, LS2 intake and would like the 6.0 PCM programmed to match it.
If your doing a LS swap, this will make your life a lot easier. Wiring can be a headache wit chasing broken wires, and bad connections. Put an end to it with PSI stand alone engine harnesses. They are custom built for your application and come with new OEM quality connectors, fuse panels, and wiring. The wires are even tagged, so you know where each wire goes.
#33
The perfect harness for your LS swap project. PSI makes it easy with a stand alone fuse panel, new wiring, and harness tags so you know where each wire goes. All of this pinned out with new connectors custom built to match your setup. No more cutting or splicing.
