Envoy LS motor auto to manual.
Hello, I am looking for an LS1 6 speed manual to swap into my Scion FRS 6 speed manual track car. I have read that using a truck motor, assuming I am okay with the extra 70lbs because of the iron block, would be just as good with better heads, cams and oil pan. I have found a 5.3L V8 engine from a 2004 Envoy XL SLT, I am wondering if I would be able to mate a 6 speed manual transmission to this engine. I am able to pick it up for $500 with wiring harness, ecu and all of the accessories. Apparently it runs, although I will be pulling it apart anyways to rebuild. Down the road I am thinking I will end up going turbo with this engine and I am just trying to get my hands on something to start developing my knowledge with these engines.
Thanks very much.
Thanks very much.
Forgot to add, if it is possible to use a 5 or 6 speed manual on this engine. I know I would have to get an LS1 flywheel and clutch kit for it.
