Need help with aftermarket tach for LS swap
Old 06-16-2015, 09:10 PM
Streetracer09's Avatar
Default Need help with aftermarket tach for LS swap
Car is an 87 G-body. It will have an aftermarket Dominator. Where will the aftermarket Autometer tach tie into with the engine? Will the Dominator pick up engine RPM from it's own signal somewhere?
Old 06-17-2015, 06:32 AM
lsxRanger94's Avatar
https://ls1tech.com/forums/conversio...er-gauges.html
There are a couple of ways to pick up tach signal. Don't know about a Dominator. But you can get them from the coil pack as well as the pcm. Hope this helps.
Old 06-18-2015, 10:54 AM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
The Dominator has a "tach out" wire (blue/white stripe) that you can connect directly to the Autometer tach. The Dominator ECU will determine engine speed from the crank sensor.
Andrew
Quick Reply: Need help with aftermarket tach for LS swap
