6.0 swap into 2001 camaro??
Car originally had a ls1, 4l60
That was pulled along with the harness for a swap into a third gen. Now this car is getting rebuilt with a 6.0 and 4l80e pull out. Just a few questions. Will the truck accessories work under a 4th gen hood? I know they do on a third gen. Any other accessories besides f body that fit? Had I reuse the truck harness or do I need a f body harness? Will the stock a4 shifter bolt up the the 4l80? Is driveshaft different length with a 4l80 from a 4l60?
I'm a newb I know... This is my first swap into a 4th gen and am overwhelmed. I'm a third gen guy..
L99/LS3 5th Gen brackets/accessories will fit (They have Truck spacing & do not require a Balancer change), GTO/G8 brackets are very close also. (4th gen F-body spacing) Truck brackets will not work.
The Truck harness is completely backwards, I tried to modify my '04 5.3L harness....It will not work without ALOT of splicing/rerouting Or new wire & crimping. BP automotive built my harness, I am very happy with it!
I just don't know what fits in your engine bay, as I'm 1st gen only. But there is someone out there that sells the brackets you need, I can guarantee that!
I had good luck with the guy from lsbrackets.com, he was very responsive to all my questions. Dirty Dingo is another option for relocation brackets.
I just found them, interesting. I'm staying efi also so some type of relocation bracket is needed if keeping truck accessories so I can put the efi intake on it. This is good info. Thanks. I found that gm sells the gmpp kit for 700 ish also with all brackets and accessories but that is pricey.
Yeah, I have a friend that used the GMPP kit with an LQ9 and an LS3 top end. It's a great deal if you want/need new accessories. But if you can re-use your old stuff, there's other options. We both stayed EFI as well, mine just looks like a carbed setup to the casual onlooker (Vic Jr. & 4 barrel TB).
