innacurate speedo in '94 bird after LS swap
i put a 5.3 into my '94 firebird, but my speedometer is reading about 30-35mph while i'm going 70mph, is this something in the tune that we missed?
i'm also having a high idle issue, it's idling at about 1500rpms and sometimes goes down to about 1000rpms. i thought IAC but i swapped it out with a new one and it still isles high.
thanks for any advice guys, much appreciated.
T56 or auto? I would check for vacuum leaks causing the high idle. Computer most likely has to be tuned for the speedo. Also are you running a egr? Throwing any codes?
I am having the same issue as you with the speedo. I have been just using my gps. I need to get it fixed some time soon.
T56. i sprayed starter fluid around looking for a vac leak and couldn't find anything, i'll try again.
i think something needs to be done in HPT for the speed, i'm just not sure what. i believe we had to change the value of something to get the RPMs correct.
No EGR, only code is for EGR.
Did you hook up the small vacuum port on the back of the intake? Have you hooked up the vacuum canister and vacuum line going to blower housing? Any exhaust leaks? I can't help much for the tuning as I had someone do mine. I know he set the rpm value at 3. He also deleted my Egr and A.I.R from the computer.
Update gear ratio and tire size in tune. If your file in PCM is for auto and you have a manual idk if/what you can change to make the PPM match properly. If you can't change anything then upload a manual file in computer that's close to your setup and update tune accordingly.
I recently did a test. I drove my car at 20mph per the speedo and my GPS said I was going 42mph. Then I did it again at 30mph and the gps said 64mph. I then pulled my computer and sent it off to a different tuner. He just got back to me and told me I had a tune for a automatic Silverado. lol Anyhow he is reflashing it for a manual Fbody and hopefully everything will be fine when I get it back.
