fuel injetors
Old 07-04-2015, 06:09 PM
mlevario99's Avatar
Exclamation fuel injetors
I change the fuel injectors on the passenger side with some used ones that I got from the salvage yard. The engine is a 5.3, and the injectors I got are from a 5.3 as well. Do all 8 injectors need to be the same number? What happens if they are not? If the injectors I installed have more flow than the other 4 on the driver side, what do I need to do? Do I need to do anything to the computer?
Thank you
Old 07-04-2015, 11:58 PM
superdave84's Avatar
Thank you
Some 5.3s have different injectors. I think the Flexfuel ones put out slightly more fuel but I could be wrong. Some 5.3s even have the 243 heads that the LS2 has, and I would imagine that setup had different injectors a well.
I would not run different injectors on one side of the engine. Get a matching set. it might run but it's going to cause you trouble in the future at some point.
Old 07-05-2015, 09:11 AM
mlevario99's Avatar
Thanks, I will install the other 4 I have. Do I need to change anything on the pcm? Since the ones I just install have more flow at the same pressure.
Thanks
Old 07-05-2015, 11:44 AM
Thanks
Personally I wouldn't worry about it unless it runs weird after startup, or if you get some kind of code
Quick Reply: fuel injetors
