4L60E neutral safety switch
2005 4L60E with the one connector neutral safety/range selector switch. Trying to get the 411 on how to get the only start in park and neutral and the reverse lights to function through the switch. I know it has to do with pins 9-12 but have no idea how they should be wired. Anyone have a wiring diagram or write-up they care to share? Car is a 67 Nova with stock column shift FWIW. TIA Darrin
I'll be going through this also, there is so much info on the older style nss switch with two plugs, but not a whole lot on the newer single plug switch. ......
Back up lights - pink wire pin11 is ignition power.
Gray wire pin 10 goes to the lights.
Neutral safety switch - pink wire pin 12 hooks to wire coming from ignition switch.
dark green wire pin 1 goes to the starter relay 85 then 86 will go to ground. 30 will be battery power, and 87 goes to the starter solenoid.
