Rear End Shake. Drive Shaft Phasing??
I put a 5.3/T56 combination in my 1998 Ford F150. The factory 4.2 V6 was dead when I purchased the truck already knowing I wanted to do the swap. I made the front motor mounts and modified the Ford transmission crossmember for the T56 pattern. I had to add a 3/4" aluminum shim to get my driveshaft angle correct. Generally speaking, I have been very happy with the swap but it has always had a rear end shake upon braking. I replaced the front rotors/pads. Added new Earls stainless brake lines then new drums/shoes to the rear. I disconnected the ABS thinking a bad sensor might be causing the shake. I even took the entire rear end of my 1997 F150 which works perfectly. I replaced the rear springs and added Bilsteins all the way around. The truck drives amazing but.....still has that rear end shake. The only part that's old and rather worn is the bushings in the rear hanger. Now there is no vibration upon acceleration or cruising. What else can I look for? Worn transmission mount? Driveshaft phasing is incorrect? I need ideas.
Just under braking. If I get on it hard during acceleration and break the tires loose, it doesn't even wheel hop. So that's was so confusing. It's hard to diagnose because there is no other situation other than braking that causes the condition.
But the rear end I installed worked perfectly in the truck I pulled it from. I did nothing but install it. No brake work. So maybe the way the brake fluid is modulating??
Found the problem.....
I bought a used T56 and the bushing in the tail housing is badly worn. Time for a total rebuild as the trans is starting to pop out of gear when de-accelerating in second gear.
Thanks everyone for your input.
