New Hooker 3rd-gen F-Body LS swap System Preview
#61
It very well may work with engine brackets other than the Hooker brackets I developed in conjunction with the crossmember, I just have no ability to tell you if it will or not.
#63
The headers are designed for fitment around 4th gen engine mounts, but I have no idea if they will clear the Spohn K-member or not...I guess you'd be rolling the dice a bit to find out.
#69
Hooker 3rd-gen LS swap system part numbers
I'm posting these part numbers for you guys who have asked for them...none of these components are on the shelf yet and some of these part numbers haven't even been entered into our system yet, so don't go hitting up your favorite parts source to place an order at this time as there's no way for them to be able to process it for you. I will keep you posted as to when each part is actually released and capable of being ordered.
70101316-RHKR- 1-3/4” x 3” long-tube headers, 82-92 F-body LS swap, stainless steel
70101315-RHKR- 1-7/8” x 3” long-tube headers, 82-92 F-body LS swap, stainless steel
71221003HKR- 82-92 F-body LS swap engine mounting bracket kit
71222005HKR- 84-92 F-body LS swap transmission crossmember
71223003HKR- LS swap 4L80/4L85 transmission crossmember adapter bracket
71223004HKR- LS swap 4L60-4L70 transmission crossmember adapter bracket
70501326-RHKR- 82-92 F-body header-back exhaust system, 2.5" - 304SS - Auto Trans
70501426-RHKR- 82-92 F-body header-back exhaust system, 2.5" - 409SS - Auto Trans
70501339-RHKR- 82-92 F-body header-back exhaust system, 2.5" - 304SS - T56 Trans
70501439-RHKR- 82-92 F-body header-back exhaust system, 2.5" - 409SS - T56 Trans
71223006HKR- 82-92 F-body fuel/brake line heat shield
71223007HKR- LS engine starter heat shield
#72
Are the faux dual-tips required? I'm a function-over-form guy, and I don't see them improving function. I understand that people think dual tips look better on 3rd gens. My current setup is a single 3" on the driver side; I'd be happy with a straight single on each side.
Also I see you list the years for your transmission crossmember as 84-92. I understand why, having an 82. But I've been using later crossmembers in it, both factory and swap, since 1999 - I just modified the mount bolt holes and nuts to accommodate them. Latest version is a 1/4" plate drilled to match the later bolt pattern, nuts welded to the plate, and slid into the frame member, one plate per side. Don't want to discourage 82-83 owners from thinking they can't do this swap - you just need to do a little extra fabrication.
One last question: Are your engine compartment pics of the 1-3/4" primary, or 1-7/8" primary? I have 1-3/4" now, and I'm putting together plans to give it a little more punch, and think the 1-7/8" would be preferred for what I have in mind.
By the way, outstanding work. It's great to see a quality company like Holley supporting our platform. I'm liking the looks of what you're doing here.
Now if we can figure out how to fit a Hi-Ram under a stock 3rd gen hood...
(And if you happen to see Matthew Lunsford, that crazy new hire with the turbo LS Foxbody, tell him More Door says hello...)
#73
#74
Thanks for posting five7kid. The tips are actually not faux as the dividing wall between the tip legs is fully windowed. Dual tips are used on this kit for the simple reason that it the only way to have the tips equidistant on the car with 6" diameter diameter mufflers mounted at the rear of the car, which is how the excellent sound/tone of this system is acheived. Individuals have mounted large mufflers in these cars by modifying the spare tire and or trunk wells, but that was out of the question for us. You could choose to install single tips on the system, but they will exit under the bumper with a left shifted bias off of center, which may not be noticeable to some people.
I did try to mount mufflers there on my '82 LS1/T56 swap, so I know where you're coming from. I ended up removing that system and going with a more conventional 3" single, but my problem was we didn't route the exhaust pipes like you are. Your solution is much better.
We design and market all of our LS swap components to be bolt-on parts, which is the reason for the 82' and 83' model year exclusions for the crossmember...users will figure out through guys like yourself that it can be installed on those cars if they are willing/capable to do the work.
He's obviously in the right place...
#75
Okay, that probably came off as disparaging, which wasn't the intent. I should have asked instead of making assumptions. I also have a C4, and some of the things that were/are done with tips on those cars is just crazy.
Fair enough. Perhaps a footnote that modifications are required for use on '82-'83? (But you know your standards better than I.)
Awesome!
Awesome!
#76
Just a little more about what I was thinking about the dual tips: since the outlet of the muffler is the same size as each tip, having one tee'd off the other wouldn't improve flow. But, you're doing more than just working on flow, apparently.
(On another topic, have you considered Tri-five LS swap 1-7/8" primary headers? I have your 2292-1's, I think they might be holding my engine back a little.)
#77
I'll try to play nice, anyway...
Hah, ain't that the truth. As my old Army sergeant used to say, some people wouldn't be happy even if you hung them with a new rope...
#78
Just a quick post for you 3rd-gen F-body swap guys...I'm attaching a PDF tech sheet here for this application that should answer a lot of questions you may have regarding what these new Hooker components can, or cannot, help you achieve your project goals.
#80
