Oh hello LS 370z
Old 11-24-2015, 06:30 PM
blak max's Avatar
[youtube]/xneDF_0KAuk[/youtube]
[youtube]/7NIrutwyqAg[/youtube]
Old 11-25-2015, 07:18 PM
74CHEVC10's Avatar
Swweeeeeetttt!!!! Cant wait to see more of this
Old 12-07-2015, 12:00 PM
makeyourowndestiny's Avatar
I am very interested in this setup, I have been wanting to do this on my 370 for a while but the main thing holding me back was being able to drive it on the street. I called fueled, waiting on a response. The only lights I see you have on are the VDC and traction slip lights. Are you able to get this inspected? If so which Ecu gets used at inspection station? Also why did you opt for an auto instead of 6spd?
Old 12-09-2015, 07:05 PM
Project GatTagO's Avatar
Received 1,388 Likes on 877 Posts
Please replace the AN adapters for the fuel rail (and the fuel filter inlet and return) that use the plastic clips before you burn your car to the ground!
Andrew
Old 12-10-2015, 04:10 PM
96 Comp T/A's Avatar
Andrew
I second that, those must be pretty old stock to have those. They replaced those with a billet aluminum piece that screws in and captures. Don't let your hard work become a bonfire!!
Old 12-10-2015, 06:14 PM
MarkZ's Avatar
Dang cool.
Old 03-09-2016, 02:17 PM
blak max's Avatar
some update since my last post:
new parts in:
everything seemed set but had some tranny issue
took a few months and shipped out the tcm and ecu them realized someone had neglected to put the transmission filter back in. i bought one for $10 and it fixed the problem for a little
Old 03-09-2016, 02:20 PM
blak max's Avatar
Old 03-09-2016, 02:22 PM
blak max's Avatar
After taking the Z out a few times , i found I have an overheating issue..
rewired the oem radiatior fan
added an adapter for steamvent and rerouted the heater core lines which could have had trapped air.
replaced the thermostat just in case
Old 03-09-2016, 02:28 PM
blak max's Avatar
have a link for these?
Old 03-09-2016, 02:31 PM
blak max's Avatar
I got to drive around for a few days. didn't want to go too far since i dont have exhaust. only longtube headers
Old 03-17-2016, 03:52 PM
  #32
blak max's Avatar
more parts in :
Install day :
some fender fitment issues
more parts :
Old 03-17-2016, 03:53 PM
  #33
blak max's Avatar
more parts in :
Newest sponsor CSF Radiator
Old 03-17-2016, 04:17 PM
  #34
Sebtarta's Avatar
http://www.summitracing.com/parts/rus-644113
http://www.summitracing.com/parts/rus-644123
http://www.summitracing.com/parts/rus-640940
If you have Amazon, they are all Prime as well FYI
Old 03-17-2016, 05:57 PM
  #35
blak max's Avatar
thanks...so i would be replacing these 2 feed and return and the one at the fuel rails? do they go bad?
not this?
Old 03-17-2016, 06:10 PM
  #36
blak max's Avatar
found the answer
Old 03-17-2016, 06:53 PM
  #37
Austin_Jim's Avatar
Andrew
Andrew - This may be a little bit of a newbie question, but can you please expand on this? I am collecting parts for my swap and want to make sure my fuel system is not a target for Smokey the Bear. Do you have pictures with arrows saying what not to use and a link to what I should be using? Or possibly a thread I can read?
Thanks,
Jim
Old 03-17-2016, 09:25 PM
  #38
blak max's Avatar
the Russell push-lock to AN fittings come in two types. One has a terrible design flaw that will cause it to pop off and spray fuel everywhere. The other does not.
Do NOT buy the ones with the plastic inserts. They're the same inserts the OEs use, but Russell screwed up the implementation. I've had them blow off at the track. We've had customers blow them off before we sent out replacements. Get the two-piece units.
Car-B-Q special on the left, good fitting on the right.
info i found on another forum
Old 03-18-2016, 06:50 AM
  #39
Austin_Jim's Avatar
Thank you sir. I did trade PMs with Andrew as well. I'm glad I saw this, I had the bad ones on the shelf waiting for my build.
Old 03-18-2016, 11:50 PM
  #40
blak max's Avatar
my lines at the regulator are held in place. i doubt they'll move but ill probably change out the fittings there and at the fuel rail
Quick Reply: Oh hello LS 370z
