Couple of hopefully easy wiring questions
using lt1swap.com instructions for modifying a 2000 truck harness - I have a #42 pin in the Blue PCM connector for fan but not sure if it is supplying a ground or 12v for the relay.
also #9 in the Red PCM connector for the fuel pump - Same deal - is this supplying ground or 12V?
Thanks
Thanks
pin 42 will go to a relay if you use a electric fan. relay will require you to run a ground. 12v positive from battery, your 42 wire, then wire from relay to fan(4 prong relay).-----pin 9 in red goes to fuel pump relay as signal wire. (4 prong relay)relay requires a ground, 12v positive from battery, your #9 signal wire and then a wire run to pump. I put fuse links in both fan and pump positives. Lt1Swap.com has you wiring fuses in the 4 place fuse block if you did as he did.
yes both are trigger wires for relays. I run my grounds from relay to back of engine with other grounds as they all be same place. no searching for them later if together.
LS1Tech Sponsor
Bill
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
