want to put a 427 in my 94 camaro
If all you want is a 427, take your LS2 and bore and stroke it out too 427. You well avoid many areas of problems.
But if you really want a 427/Z06. Then your going to have to deal with 1) dry oiling system, 2) engine management and wiring, 3) wiring integration with your 94 body systems.
BC
BC
Keep in mind you can always swap a F body pan so you can go wet sump. You have to get some adapters for the crank and go with a different oil pump. Don't know all the details, but I saw a how to article on it somewhere on the internet.
