LS swap Dynatech headers same for 2nd gen Camaro and Firebirds?
Hi Guys
My friend has a 78 Firebird and wants to switch from the original LS1 manifolds to LT's. After doing my research, it seems dynatechs are the way to go but summit only lists them for 78 Camaro and not 78 Firebirds and none of the forums actually say anything about this or list part numbers.
So my question is, is the Dynatech LS swap headers, Dynatech 715-29410 and Dynatech 715-19410, the same for 78 Camaro as 78 Firebirds since they are both F-body cars?
Thanks
Thanks
Hi Guys
Thanks
Thanks
Andrew
http://www.nastyz28.com/forum/showth...=250824&page=2
Just search on google: 2nd gen camaro dynatech ls swap headers
EDIT: Sorry, i read that wrong. I beleive the headers are from an 04 Caprice thats sold in the Middle East or Holden Caprice depending on where you live. You guys never got those stateside
Dynatech Headers and Collector Height
Just for some added information about the collectors fitting great or hanging low on Dynatech (or any header for that matter). We all know that when you raise or lower the engine, the headers follow the engine. In other words, when you lower the engine and or transmission the headers will be lower to the ground as well. The most important thing a customer can do is make sure they are using the same mounts and adapter plates that the headers were designed for use with. This will probably explain why many customers love the fit and others have issues with them hanging too low.
For example, the Dynatech Headers were designed for use with:
1. Speedway Motors Adapter Plates: Part# 910-18012. Different Adapter Plates vary in thickness and locate the engine in different locations. Many can even be flipped upside down.
2. Small Block Engine Stands. These are the parts that are between the engine mount and the engine cross member. The Big Block stands will set the engine lower.
3. There is also as much as 1.00" variation between the different styles/brands of engine mounts. If the engine is setting too low, you may have mounts that are too short.
Hope this helps prevent some headaches.
Id like to order today
Thanks
I am pretty sure we spoke, however just in case we did not, yes they are the same. Your original mounts may differ a little from the Small Block Chevy Mounts considering the Firebird used a Pontiac engine. Other than that, every thing else should be fine. Thank You again for your interest in our products.
