Which setup for LS to Dodge Dakoat swap
I've got a 99 Dakota 2wd 2.5 that is in desperate need of power. And like most have decided the package of an LS is hard to beat. I'm trying to decide on which years are best and if I should get a 5.3 or 6.0. I'm thinking starting with a complete dropout would be the easiest. Normally on engine swaps I would try to keep all the OEM electrical and PCM and just marry the engine harness to the existing body harness but with all the aftermarket LS PCM's out there maybe factory isn't the best choice.
Truck will be used mostly for towing the toys and not a muscle truck but running low 14's or better would be fine with me.
So decisions are:
5.3 or 6.0
Any years better or years to avoid
Which auto trans
Factory electronics or Aftermarket
So decisions are:
5.3 or 6.0
Which auto trans
Either engine will work fine, your gonna pay up for a 6.0 and a 4L80e probably won't fit without some trans tunnel modifications. A 5.3/4L60e combo can be had for an affordable price and the 4L60e fits with only minor hammering. I used factory truck manifolds and built the rest of my exhaust from scratch. Do yourself a favor and call one of the vendors and get a stand alone harness. I used the factory fuel system but control it with the gm ECM.
I agree with the choice of the 6.0. I used an LY6 and managed to fit a 6l90 with only minor modification to the tunnel. You should be able to fit a 4l80 without too much trouble.
As for wiring, you can use a GM ECU and harness, and have it modifed to be stand-alone by any number of vendors on this site. Find a tuner who can tune with HP tuners, and you are all set.
And its better to have more power than you need rather than
needing more power and not having it.
I vote for 6.0 and doing whatever it takes to make it work, you should only have to
do the hard part once. After you get it all in and running, pulling it out for a cam swap
will be a breeze. my .02 good luck
