Dakota Digital pass threw 8k pulse wiring
Has anyone used this with a 99-02 pcm? If so how did you wire it? Black and gray wires coming from the sensor, green/purple from the ECU?
I used the BIM module and am taking all of the readings off of the PCM for my VHX gauges. I am using the GMPP harness and it includes the oil pressure. Some harnesses have the oil press sender wired while others don't (some of the aftermarket ones). You can also read other PCM reading like IAC and others to help you trouble shoot problems you might have. Works great and less wiring to do. I bought a OBD Y cable to run the DD stuff off of one and still have an open one for a scanner if needed.
http://www.dakotadigital.com/index.c...rod/prd752.htm
I just bought the DBC Cruise Control conversion from DD. Hope to start installing it in the next couple of weeks.
I did end up connecting Black to Green and Purple to Gray and changed the speedo settings in Hptuners to 8K per mile, and changed the gear ratio to 3:42. But when hooked up to VCM scanner in Hptuners when I am driving it flickers from 1-2 mph no matter what speed I am moving
