Fuel Injector control wire routing
Old 10-26-2015, 09:45 AM
1976CamaroGuy's Avatar
Default Fuel Injector control wire routing
I just wanted to verify the numbering on this diagram, corresponds with the numbering on the cylinders?
I'm not talking about firing order, I know thats different. I just wanted to make sure my wire routing is correct based on color wire and PCM Pin location
2004 Truck Harness
Pin Wire Color Function PCM Connector
36 BLK Fuel Injector 1 Control Blue Connector
3 PNK/BLK Fuel Injector 3 Control Blue Connector
76 BLK/WHT Fuel Injector 5 Control Blue Connector
43 RED/BLK Fuel Injector 7 Control Blue Connector
4 LT GRN/BLK Fuel Injector 2 Control Blue Connector
44 LT BLU/BLK Fuel Injector 4 Control Blue Connector
37 YEL/BLK Fuel Injector 6 Control Blue Connector
77 DK BLU/WHT Fuel Injector 8 Control Blue Connector
Old 10-27-2015, 08:42 AM
1964SS's Avatar
Yes it does. This site will have all the info you need.
http://lt1swap.com/2004vortec_pcm.htm
Quick Reply: Fuel Injector control wire routing
