Yep another 5.3 turbo fox aka "tha myth"
Old 11-03-2015, 09:50 AM
Clean94Z's Avatar
Default Yep another 5.3 turbo fox aka "tha myth"
Well I wish I could tell you this was some off the wall different setup but Id be lying.. Its your typically BUDGET LS turbo fox. I would say 90% of the parts are used. As of yesterday I have owned the car for 2 years and its already done some street racing and been in a few videos. Figured it was time to throw it up on TECH.
Quick run down:
04 LM7 5.3 {regapped rings}
228/228 cam
pac springs
ls9 headgaskets
ebay headstuds
s475
th400 manual vb
e85
160lb injectors
magnafuel 4303
Sorry for the pics being in black and white. Only a handful of people knew about the build until till ran.
How I bought the car
5.3
Without these two I couldn't have done it!! Two kick azz guys
Old 11-03-2015, 09:54 AM
Clean94Z's Avatar
th400 revers vb with brake
rats nest!! previous owner!!
AJE
Old 11-03-2015, 09:57 AM
Clean94Z's Avatar
ptfe fuel line
homemade dash
Old 11-03-2015, 10:02 AM
Clean94Z's Avatar
my buddy kevin did all the wiring!! amazing job!
before
after
he modded the Tahoe DBW pedal
my buddy dave did the turbo kit. I bought the hotside from him
Old 11-03-2015, 10:04 AM
Clean94Z's Avatar
hurst pro matic modded for look like stock 5 spd
c02 for boost controller
battle boxes
new edge brakes
Old 11-03-2015, 10:06 AM
Clean94Z's Avatar
front coil-overs
Old 11-03-2015, 10:15 AM
Clean94Z's Avatar
EBAY BLANKET
Some used wilwoods
Old 11-03-2015, 10:19 AM
Clean94Z's Avatar
And her it is!!! Yes its a POS!! just the look I was going for....
Changed to front exit exhaust and 28's
Old 11-03-2015, 10:20 AM
Clean94Z's Avatar
tested the local E85
Tested some boost
Old 11-03-2015, 10:38 AM
Clean94Z's Avatar
To get it too this point here was the $$$$$$ break down! I bought as much used stuff as I could and searched for the best deals I could. I tried to spend the money where it was needed.
Mustang build sheet
Car $850.00
Motor complete w/harness&ecu $850.00
Trans w convertor&shifter $1000.00
K-member w/mounts $400
Trans mount $50.00
Rails $140.00
$3290
Cam $399.00
Springs $300.00
Pushrods $100.00
Ls9 gaskets $100.00
Studs $60.00
Cell $100.00
$4349.00
Reg $175
Fuel lines and fittings $230
Coil overs rear w/strange $200.00
Lower arms $50.00
Turbo $575.00
Pan $150.00
Turbo kit w/ intercooler $275.00
Rad $85.00
$6089.00
Injectors/pump/filters/injector driver $750.00
Axles/brakes $550.00
$7389.00
Boost controller $600.00
Wastegate $350.00
$8339.00
Yoke-joint $75.00
Gauges and wideband $580.00
$8994.00
A-arms/camber casters $100
Front brakes/wheels $300
Frame connectors - Xmas
Battle boxes $60
Strange struts $100
Coil overs $75
Co2 bottle/Reg $100
Anti roll bar $200
Driveshaft loop $70
Bump steer kit $100
$10,099.00
Intercooler piping kit $67
Electric fan $110
Vacuum box $12
$10,288.00
$300 new edge brakes
$250 gears and bearings
$10,838.00
Old 11-03-2015, 10:41 AM
Clean94Z's Avatar
The car runs hard! Here it is doing alittle street racing in Mexico. timing at 14* and 11psi
Old 11-04-2015, 05:31 AM
booboo37's Avatar
So how fasten in the 1/4 ?
Old 11-04-2015, 07:36 AM
Clean94Z's Avatar
No clue.. I have a wolf cage sitting in the corner of the garage I hope to get installed over winter.
Old 11-04-2015, 11:48 AM
Nismo Kid's Avatar
I'm diggin the build. What city was the E85 tested? I've seen mixed results here in San Antonio. The Valero @ UTSA & I10 has always been pretty consistent.
Old 11-04-2015, 12:19 PM
Clean94Z's Avatar
Thank you!
The Valero is in cedar park. The HEB is in Austin.
Old 11-04-2015, 07:48 PM
onebadbowtie86's Avatar
What was the flashing light from when the cars went under that overpas thing? Speed cameras?
Old 11-04-2015, 08:12 PM
Clean94Z's Avatar
Toll roads
Quick Reply: Yep another 5.3 turbo fox aka "tha myth"
