1970 Chevelle 5.3 swap ( stumbles in low rpm)
Old 11-13-2015, 12:12 AM
FearReborn's Avatar
Default 1970 Chevelle 5.3 swap ( stumbles in low rpm)
Well officially took my car out on a test run tonight. Seems to be bog off the start but when it opens up ( around 3 to 3500) holy **** it runs like a raped ape. 5.3 with z06 cam 2500 stall. LS6 intake, 0411 PCM flashed to my specs. If you rev the car in park it never Boggs out. only does it under load. Have about 2 gallons in the tank ( tanks inc tank walbro pump). Hoping maybe that's the problem. But did have a code popping up after test starts. 0351 0353 0355 0357. When I got back from the test drive it read zero codes though. Have aftermarket coils on but all brand-new.
Old 11-13-2015, 09:58 AM
Alwhite00's Avatar
Two gallons in the tank isn't a hell of a lot. I would definitely try putting some more fuel in it.
Old 11-13-2015, 11:11 AM
ls1nova71's Avatar
Definitely put some more gas in it! It's likely all running away from the pick up when you take off causing it to bog down, then once you're moving it runs back to it.
Old 11-13-2015, 05:12 PM
FearReborn's Avatar
No one video I got of it you can barely hear it breaking up but it seems like sometimes it's going into limp mode or the pedals not responding
https://www.facebook.com/groups/258057997644232/permalink/849559425160750/
Old 11-13-2015, 05:48 PM
12NVRICH's Avatar
Check the throttle position sensor mounted on the side of the throttle body. Mine did the same thing twice don't buy a cheap one either. They are not cheap so maybe you could convince a buddy to swap his before you pull the trigger. Takes less then 10 mins to r&r.
Old 11-13-2015, 07:40 PM
FearReborn's Avatar
Kinda sucks came off a 50,000 mile z06. Are the sensors the same on Corvettes as truck? But the motors sat for a while so it could have got gummed up. Can you clean these?
Old 11-13-2015, 09:51 PM
Old School Heavy
speedtigger's Avatar
The gas tanks in these cars are just not designed for fuel injection. The fuel level must be kept high in a stock tank.
Old 11-13-2015, 10:05 PM
FearReborn's Avatar
Guess I should have said this. It's a tanks inc fuel injection tank with in tank pump and sump
Old 11-13-2015, 10:06 PM
12NVRICH's Avatar
Not really unless if you remove it & the rotation is stiff from dirt or gum. The electrical contacts get worn after awhile. You can diagnose with an ohm meter if you are electrically inclined. If you scanned it it should show faulty tps? It could be a bad fuel pressure regulator. Do you have a fuel pressure gauge? Should read around 58 to 60 psi at idle, partial & wfo.
Old 11-14-2015, 12:16 AM
FearReborn's Avatar
Going to check the pressure tomorrow. Everything from the tank to the rail is new. Hoping it's not a weak pump. Have the corvette filter/regulator
Old 11-15-2015, 05:08 PM
FearReborn's Avatar
Did a pressure test today. When you hit the ignition and jumps up to 57then leaks down back to zero turn the ignition and start the car and it holds at 57. Reving it does not affect it... stays right at 57. Is it normal to leak down back to zero or should the Pump hold them rails at 57 with the key to on position
Old 11-15-2015, 05:29 PM
33willys's Avatar
Default 5.3 stumble
Your codes are all for coils and kind of indicates to me there is a small lack of ground somewhere. Recheck all grounds and add star washers. I think the Walbro pump does not have a check valve so pressure would bleed off quickly but while running you have good fuel pressure.
Old 11-15-2015, 11:07 PM
pdsq98gt's Avatar
Has it been tuned yet? Could be leaning out from the tune although that's not that big of a cam. Is the torque converter a good quality brand?
Old 11-16-2015, 02:32 AM
FearReborn's Avatar
It's a torco converter, but it seems fine though. But it hasn't been tuned yeah just set initial flash to get it running. Told all my specs converter stall all of it should have been specked to the motor. going to find a local shop to check it.
Quick Reply: 1970 Chevelle 5.3 swap ( stumbles in low rpm)
